Best Video Editing Software
I’m interested in editing videos and thinking of uploading a short movie on YouTube. Is there any video editing software that is easy to use?
Having good software does not matter that much. The skills that you produce out of this is what counts. So I would suggest you, watch some tutorial detailing all the basics about the software you’re going to buy.
Adobe After effect or Premiere pro :
Premiere Pro is easy to operate as well as to learn. You can also edit with after effects, but it is very hard to do so compared to premiere pro. After the effect is for motion graphics and composting. You can do all the things like adding 2D animations, texts in premiere pro, it is quite hard to so compared to after effects.
So if you’re thinking of making video editing as your career, I would suggest you, buy both of them. If you’re only into editing and giving your video cinematic effects rather than VFX, then I would suggest you, go for premiere pro.
