Best Way To Clean A PC Without Deleting Data And System Files
I need to free up some space on my PC without deleting the important data and the system files. What is the best way to clean a PC?
The Disk Cleanup utility is an exceptionally basic apparatus that permits you rapidly erase stuff like brief.
In Windows 8.x, you have a few choices. The simplest is to hit the "WIN" key and sort "circle cleanup" and after that pick "Free up plate space by erasing pointless documents."
At the point when "Circle Cleanup" starts, on the off chance that you have more than one drive introduced, you should pick the one you need to cleanup first. Here in our illustration, we pick the framework drive (C:).
Note here in the accompanying screenshot, we've restarted in regulatory clean-up mode and "Circle Cleanup" has found another 500 MB of space it can free up (Windows Update documents).
Notifications
