Best Way To Clean Your Computer Of Viruses And Other Infected Files
I believe that my PC is attacked by some infected programs and hence it is not performing the way it should. What is the best way to clean your computer of viruses?
Answered By 20 points N/A #131157
• Enter your PC in the Safe Mode.
• Delete all the temp files.
• Download the Malwarebytes Scanner Antivirus.
• Install the software and run using the admin rights.
• Run a thorough scan of your computer and delete the infected files and programs found by the Malwarebytes.
• If the Malwarebytes disappears in between the scan that means some infected file is preventing it from completing the scan and hence you need to re-install the Windows.
