Best way for hard disc diagnostic MAC
I am using MAC pc and I'm worried that my computer is at risk of hard disk failure. Is there anybody here who can tell me what's the best way for hard disc diagnostic MAC? Please tell me, I really need your help. I have important files saved there and I really need to save my computer's hard disk. Thank you
Answered By 5 points N/A #144800
Dear user,
If your mac starts properly then you should make a backup for your data in your mac's hard disk. If you are hearing audible clicks from your hard disk, then it's better to replace it with a new one. You may run Mac’s native Disk Utility application by which you can determine whether your hard disk is having a problem. Now you have to select mac's system disk and click the Repair Disk button found on the First Aid tab. If it indicates damage in your hard drive, then you should have to replace it. If you want to further diagnose bad blocks on your hard drive, then you can use disk tests such as DiskWarrior.
Hope this will help you.
Thank you.
