Best way to remove virus from Hard Disk
The best way to remove virus from hard disk is by running antivirus, antimalware or anti spyware software on your hard disk, this will be best method and remove all the viruses. But in order to prevent reoccurrence of viruses, you should install a good antivirus on your hard disk. As the free version of anti-viruses expired with time, so keep updating that when your computer updates you.
Otherwise formatting will also removes all viruses but it will affect our existing data. If you have backup of all your important data the format your hard disk without wondering.
Dear Jerry Kent,
Virus is the difficult problem in desktop computer / laptop. Totally remove virus is not easy but the best way to remove virus from hard disk you can follow these steps.
At first you can break your hard disk partition than you will make new partition and install Windows newly. After completing installation, you will setup any license version anti-virus and update it.
I think this will solve your problem.
Thank you.
