alitatmaja
Posted on - 08/28/2011
Hello, I would like to combine my contacts that I kept on my Blackberry Bold 9700 (Blackberry OS version 5.0.0.979) and my HTC Incredible S (Android Froyo 2.2).
I know that I can synchronize my contacts in my Android phone to my Gmail account. But how can I also synchronize those contacts to my Blackberry instantly using software or tool that free. Or should I buy some software from Blackberry App World to do that?
I’m looking forward for the best solution about this. Thank you for the time and solution.
The best way to synchronize Android contact and Blackberry contact for Free
Since you don’t have a problem with your HTC Incredible S, lets just proceed to the synchronization to your blackberry.
Talking about buying software from blackberry website. You don’t need to do that because we are in the era of open source. Most software we need is just a few browse away. Google have this useful software and it is absolutely free. It is Google sync. You can browse through the features for this software available from the internet. Just download the application and install it. Then change Application permissions for Google Sync to “Allow” for all 3 options. And then reboot. For best result better pull the battery off and insert it again. After the reboot, synchronization should work fine.
