The best way to use a free web visit counter graph.
Dear web developers,
Hi, you did not specify which graph counter you are using. The instructions for fixing the problem are specific to the type of graph counter. For these problems, a reset of your counter is advised. Resetting is specific to the product you are using, and you will have to look at their documentation.
If that does not help, get another provider, they are many out there.
It may be because the codes from the web counter are pulling data from a dead web site. Counters simply copied from the internet especially their code tend to grab some bits of information from the developer's web site. Please check the Javascript sources if they point to a valid or existing file. Also check for other areas of the code that may need bits of data from external web sites that are no longer available. Hope this helps! Cheers!
