Best ways to keep my computer safe on the internet
Hey Calvin Montes!
There are many ways to keep you safe on the internet. There is an option of windows firewall in your computer. You can enable this option. The purpose of this firewall is to block the virus attack from the internet. Alternatively you can use some antivirus like Norton Antivirus or Avast Antivirus. These Antivirus also block the virus attack from the other party.
However if your browser opens such page which has malicious virus your Antivirus will block this webpage and will prevent from opening it.
Try Norton or Avast, both of these are very useful.
Hope you understand.
Thanks
Hi calvin
As you know there are millions and millions of users using the internet so it is necessary to use the ideal ways of protecting the computer.i can help you by telling some of them
1. Use best antivirus and try updating it daily.remember avoid using two antivirus at the same time.
2. Always keep your firewall on so that you are always secured.
3. Install an anti spyware software on your pc.
4. Do not disclose your WiFi password to unknown persons or even your neighbors which you don't trust.
5. Try not to read junk/spam emails and never download any attachment from them.
6. Try downloading only those software's whose providers are secure and verified.
Thank you for the responses. They’re very helpful.
I took your advises about turning on firewall, updating my antivirus regularly, etc.
I am now careful in opening emails that might be junk/spam. Now, I believe my computer is safe.
This site helps a lot.
The internet is not the safest place for the computer. There are intruders trying to access your computer, malicious Trojans disguised as helpful programs and spyware that report your activities back to their makers. What you need to do to safe your computer on the internet discussed below:
I think it works out to save your computer.
