Best Ways To Unlock The Laptop If You Forget Your Password.
I logged out of my laptop. I cannot unlock my laptop as I seem to have forgotten the password. Is there any way to get on it without the password?
Here are some methods that might help you. They can unlock locked laptops in different situations.
METHOD 1:
Using the password reset disk If you were smart enough to create a password reset disk before you got locked out, unlocking your laptop will be simple.
Follow these steps:
1. Enter an incorrect password. You will see a password reset link.
2. Insert the password reset disk and click Reset Password.
3. A wizard will open. Follow the instructions and solve your problem.
METHOD 2:
Using Windows Password Rescuer Windows Password Rescuer is a professional software designed to recover lost or forgotten Windows passwords.
1. Install Windows Password Rescuer on another computer as administrator.
2. Run the software and insert a USB drive.
3. Select Burn to USB option and choose the drive’s name from the drop-down list.
4. Click Burn and remove your drive on completion.
5. Now boot your locked laptop using this USB flash drive.
6. Choose the user account and click Reset Password.
7. Click Reboot and remove your USB drive. On rebooting, you will be able to log in without a password.
METHOD 3:
In “Safe Mode.”
1. Open Advanced startup options during boot. Different operating systems have different ways.
2. On opening advance start-up, select ‘Safe Mode’ and press Enter.
3. Choose a user account and login to it without entering any password.
4. Now go to Control Panel and User Accounts.
5. Change password.
6. Restart
Notifications
