Dear Friends,
I am searching for a web based software solution that can be used for customer relationship management & automation of the sales force, please do the needful for suggesting the best web CRM software for Windows.
Thanks & Regards, Ethan Jessica
Best web CRM software for Windows
Take a look at SugarCRM. SugarCRM is an open-source software, so it’s free to use and you can also modify it to fit your company and your system better. SugarCRM can use for all kind of company from small to large scale. SugarCRM is one of the best web based CRM you can have.
You can modify SugarCRM to work well with other system with knowledge of programming PHP. With Sugar Community Edition (free) you can:
Automation your sales force and marketing
Support customer better
Project management
Plan management
Team work and more
