Hi! My work requires me travel a lot. I need an app that would let me handle things especially my documents in the office while I'm away. I'm sort of a multi-tasker. I was wondering what are the best windows phone printer applications available out their, and what are the printers compatible with it.
Libbys Snyder
Best Windows Phone Printer Application
There are no direct way to print from a windows phone but there are some applications are available which can help you to upload documents some places and print from there.you can also print your document with ePrint enabled HP printer by sending the documents as email from your phone to assigned ePrint email address.so this solution is better for you.
I would suggest you Sky Drive app which will allow you to store your files so that you may access them from virtually device. You can access this app from your Windows Phone's Office and pictures hubs. This app is best for you to manage and share your data. You can install this app from the following link.
The Network Printer app and Brother Printing app is compatible for your Windows Phone. You may get these applications easily from the internet source.
