Best windows Video Maker Software?
Whenever I do make my videos, I used my MacBook.
I consider Apple having the best video maker software, but my MacBook got busted.
I’m using right now my PC; I need suggestion on best video maker software for windows..
Best Answer by James tasnu
Answered By 10 points N/A #144844
Hello Christina Turner,
Well first there is a pre-installed application in Windows, Windows Movie Maker.
The best thing about it is that it's free and also effective.
Then you have some other Video Making tools like Video Pad Editor:
So good luck with your movie making and enjoy!!
Answered By 0 points N/A #144846
Use the windows movie maker.
When you are ready to export your movie file, you can see the words Movie Setting at the top.
Select the option Other settings and scroll down the list to find the best quality for you.
Just choose the High Quality Video large outputs the very best quality you can get on Windows Movie Maker.
Answered By 0 points N/A #144847
Hi Christina
Windows movie maker is nice video maker software available in Windows. It is quite easy and even efficient.
Sharing your movie has never been so easy. With Windows movie maker you can share your videos/movie on Youtube, FaceBook etc.
You can download movie maker easily¾
Beside, If you want to use some high end video maker software then go for Adobe Aftereffects which is compatible with Windows.
