After I downloaded beta2 and was testing it, this error message appeared on my screen:
Software Explorers error 0x8007065d. Data supplied is of wrong type.
I searched for post relating to this issue but I could not find one. Can anyone help me?
Thank you.
Beta 2 Software Explorer Error 0x80007065d
Dear Willey,
You have downloaded beta2 software and when testing it showing error. Error code 0x80007065d. You need to solve this problem. Here are some solutions to solve your problem. Please follow-
** Your software may be affected by virus. First, clean viruses from your computer.
**It may also caused by blocking by antivirus. Disable protection of your antivirus and download the software again and try to work.
**If still problem remains then you have problems in your operating system.
** You need to reinstall your operating system or update your operating system.
**Then you try again to download.
I hope your problem will be solved.
Have a nice day. Thank oyu.
