ashley.bila
40 points
Posted on - 05/25/2012
Hi everyone. Recently, when I want to open a Microsoft Office 2010 application, I get the following message:
Your beta software has expired. Use Add or Remove Programs in Control Panel to remove the beta software from your computer. Need a solution. Please help. Thanks a lot.
Beta software expiration of MS Office 2010
Receiving the message, "Your beta software has expired. Use Add or Remove Programs in Control Panel to remove the beta software from your computer." means that the beta version of Microsoft Office 2010 has already expired. The beta 1 has an expiration date of October 31, 2010 while the beta 2 version should have expired last November 1, 2010. To solve this problem, you should just remove the beta version and install the released retail version which you can get at the Microsoft Store online. Note that you cannot install the retail version while the beta version is still installed in your computer. Uninstall it properly before downloading the Microsoft Office full version to avoid encountering problems.
