Angela King
10 points
Posted on - 10/11/2012
Hello Experts,
Between iPad Nokia Bluetooth connection. I am having a hard time connecting my Bluetooth in my iPad to my friend’s Nokia phone. Are you guys aware on how to connect the iPad Bluetooth connectivity to any Nokia mobile phones? If you can give me a step by step procedure it will be a big help.
Thank you.
You can easily connect ipad with nokia phone via blue tooth. All you have needed to done is to Power on the blue tooth of both devices. Make it sure that both phone is in range of Bluetooth of ipad. Then pair the phone with ipad by searching the ipad by clicking on search devices. Click on send to send data from phone once paired and data will be sent. During pairing it will be requested to ipad that a device is trying to connect via blue tooth, You have to accept this request from ipad to start sending and receiving data.
Hi Angela!
It is possible to pair iPad to Nokia via Bluetooth. If you had an original model of both products it is easy to connect. Here is the step to follow:
1. Refer to the device's instruction manual for directions to found Bluetooth device. This involves holding down a button for a few seconds to pair an iPad and a Bluetooth device to other, the Bluetooth device must be discoverable.
2. IPad's Bluetooth must be on. Go to the settings menu on the iPad by tapping the "Settings" icon on the iPad home screen.
3. Tap "General" from the left panel and then "Bluetooth." Once you are in the Bluetooth screen, slide the "On/Off" switch to "On" to turn on Bluetooth.
4. Select the device you wish to pair with the iPad from the list of discoverable Bluetooth devices that appears on the screen. Depending on the device, a password may be required. Refer to the Bluetooth device's product manual for this password.
The instructions are also applicable for Nokia mobiles to have a successful pairing.
Thank You!
WarHeaD
You cannot legally connect an IPad with a Nokia phone via Bluetooth. The Apple Inc. doesn't allow connectivity of their products with other products. IPad can be only connected to other Apple products. But there are some illegal software which may allow IPad to connect with other devices such as Nokia. These software are quite available in the internet but you shouldn't use them as they can harm your device.
But if you need it badly then just download a such kind of application and use it at your own risk.
