Big clock on desktop nokia 5800
I have a Nokia 5800 and am looking for a cool widget that can display a big clock on my phone's screen. This big clock should be analog and not digital, please!
I am giving you some links from where you can get widget that display big analog clock for your mobile.
1. Visit here – https://en.softonic.com/s/nokia-5800-free-analog-clock:symbian
2. Visit here – http://forum.dailymobile.net/index.php?topic=81376.0
You will get here many widget that show analog clock and many other cool widget. I think you will love those.
Good luck
If u have a nokia 5800 handset with you. there are very simple steps todisplay clock on the screen. I will explain you step by step how to display an analog clock on the mobile screen
1 Go to "menu"
2Click on the "tools"
3. In the "tools option plesse press the "settings" button
4.Their you will find "time and Date"
5.please click the " time" button and set the time
After setting the time you need to go to the Display settings in the "settings and make screen saver as you Analog clock with the"time format' option out of "analog" and "digital" options.
you can also download an theam application from the Nokia ovi store with Analog Clock as Screensaver.
Notifications
