Big companies are always on a rat race
Big companies are always on a rat race to break their own and others record to create a new something. They are always thinking and bringing some thing new for the generation. Mac book wheel, alternative to keyboard is such an example. Are they thinking of creating a desktop or Laptop which will work by voice command?
Answered By 0 points N/A #153270
Its available now the voice command  in Mac Pro, It is  called Speech Recognition. How this happen well the Apple company has it in the operating system of the Mac OS X.  Although this is a limited command in some system but it allows the owner/user to have a control a certain aspect of the computer. Examples of the Speech Recognition that could be manipulated is the mail application, safari and address book you can access it without the use of the mouse and keyboard by just using the Speech Recognition you can access this system of your computer. In using this application you make sure that iListen voice recognition is needing to run the version 10.3 even higher. Then install the MacSpeech iListen voice recognition software, you should connect the USB headset make sure that no connection is made with the keyboard for it may interfere with the connection,  then activate it, you will find New button click on it this will make your profile, wait for a while for it to configure your computer voice and volume. Then select command Mode then you can command by voice. You can begin using it. That’s it you are using voice command.
