amona
Posted on - 09/17/2011
I am a graphics designer. I use some animation and designer software.
I see a problem when I install AnimationLab v4 software on my computer.
Error message:
"Error 1311. Source fine not found:C:Users/fowlerAppDataLocalTemppftB6B3.tmpData1.cab. Verify that the file exists and you can access it."
I try many times but same result.
Anybody have solution for this problem?
Please help me by your answer.
Thank you
Big problem in Animation Lab v4 software
The AnimationLab v4 that you have has a missing file in its set of installation files. If you acquired it by downloading in the internet then you just downloaded an incomplete installer of AnimationLab.
The setup wizard is looking for a Data1.cab file that should be located in C:UsersrfowlerAppDataLocalTemppftB6B3.tmp folder but apparently when the procedure was about to load the file, it can not be found in the specified path.
The missing file is a cabinet file similar to a .zip compressed file. Since it is a cabinet file it contains additional files in it that needs to be extracted and used in the installation process.
Since it is an incomplete installer, it’s no use to keep on trying to install it again and again. Search the internet for other websites that offer the same download of AnimationLab.
