Samsung Screen shuts down after 2 seconds
I have a big problem with my Samsung screen. More precisely, the screen turned on and connected to a computer,
Displays the office for just under 2 seconds and then seems to turn off (black screen), while the LED front panel indicates that it is on. Turning off the screen and then back,
It shows the desktop again for about 2 seconds and then seems to go out.
I searched the internet and I found nothing.
I need help.
Thank you.
Answered By 0 points N/A #130934
Answer:Hi friend I think that Samsung screen problem can be occur you can solved this problem by Samsung service code. This code will be full reset your phone. Hopefully It will be helpful to fix your problem. Just try this solution. May be it will be right code for your phone.
This is the Code: *2767*3855#
You can use keyboard for type this code and after finish type the code use keyboard enter key then your will briefly screen message and processing something after the phone will shut down and restart. Hopefully this code will solve your painful problem and your phone screen will be work again.
Thanks
James ripon
