A big problem in Program
Hello I need install important software on my PC but I can’t install it.
I see an error message when I start install that software on my computer. Many times I tried but same error.
  • Javaw.exe has generated errors and will be closed by windows.You will need to restart the program.
An error log is being created".
Now I need little help about this error. Can anybody help me?
Please share your suggestion by answer.
Thanks
Answered By 590495 points N/A #125052
I think the program you are trying to install is not really compatible with the current version of Windows you are using.
Check the documentation that comes with your software. If your software is in a CD, load the CD in the CD/DVD-ROM drive of your computer then browse it using Windows Explorer.
Look for a readme.txt file included in the installer files. Double-click it to open and read the system requirements of the program. If you can’t find it in the readme file, try opening other files and see if any of it includes the system requirements of the software you are trying to install.
Every time you do an installation, always check first the system requirements of the software prior to installation.
You may not know if your computer really supports running that program or you might need to upgrade some of its components.
