Big split view files manger
I need to split 2 GB file into several parts so that I can manage my data separate. For this purpose I need a software to split view files manger. How can I find a perfect software?
Best Answer by Sharath Reddy
Answered By 590495 points N/A #158763
That’s way too big for just a single file. I know files that usually come in these sizes are sometimes installer files and usually consume or expand to around 3 to 4 GB after it is installed.
And here, your 2 GB file needs to be divided into several chunks in order to manage the files properly and I think the reason for this is the lack of enough free space on your hard drive.
You can do this using a file compression tool like WinRAR or 7-Zip. Both of these applications let you compress and divide big files into several chunks and also protect the integrity of the whole file. To download visit 7-Zip
The latest stable version is 7-Zip 9.20 and works with Windows 98, Windows Millennium, Windows NT, Windows 2000, Windows 2003, Windows 2008, Windows XP, Windows Vista, and Windows 7.
Answered By 5 points N/A #158764
There are many software available for splitting files. Two of them are:
1. HJSplit is one of them. It is a freeware software for splitting and recombining files. It is also helpful for creating backups. A 10 GB file can be split into smaller size and can be burned on a CD or DVD or even copied to any removable disk.
2. WinRar is a easy to use utility that can unpack archive formats as well as to compress RAR and ZIP file. It can also be use to split files.
