Bind eject cd to a key
I want to know about bind eject cd to a key. Please send me the full tutorial about bind eject cd to a key.
Best Regards.
Best Regards.
Hi, Teresa Duncan
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to know about bind eject cd to a key.
So classifying and posting them on relevant forums is the best way to get your answer step by step.
I can suggest you some good forum, which is listed below
1. https://www.lifewire.com/how-do-i-eject-cd-from-mac-2260195
Or you can watch this video
Hello Teresa,
I have a solution that should help you if you're on Windows. This requires downloading a small utility named NirCmd.
NirCmd is a small utility which allows to do useful tasks. It is command line based and can do a variety of tasks such as opening a CD-ROM drive etc.
These simple steps should help –
Hope this helped.
Mclean Buono
