Bing SafeSearch settings where can i change it?
Bing SafeSearch settings where can I change it? I need to be able to make some changes to my default Bing SafeSearch.
Can I have steps and screenshots please?
Thanks in advance.
Best Answer by Suzette Heyrosa
Answered By 0 points N/A #198962
Hello Yadin,
You can change and settings in your Bing Safe Search.
1. Open www.bing.com.
2. Click the Gear icon on the top right side.
3. In the Safe Search section, select your desired setting:
  • Strict : Filter adult text, images and videos from your search results.
  • Moderate : Filter adult images and videos but not text from your search results.
  • Off : Don’ t filter adult content from your search results.
4. Save It.
Answered By 0 points N/A #198964
When you are automatically redirected to Bing which I suppose is your homepage in your case go the the setting option at the top left corner of the page, then from the safe search settings that pops out choose your desired option i.e. Moderate, strict or either off and then save it.
