I have installed the Bionic Commando Rearmed game today and when I want to add it to Steam this error appears. I can add any game to Steam except this one. How can I fix this error ? Is there any way to work this around ?
Regards !
Add a Game
No such interface supported
OK
Bionic Commando Rearmed, interface not supported
Because I’m not playing any Steam games, I thought all games available there support all the operating systems that the Steam Client supports until I saw the game you are playing. Though Microsoft Windows 7 supports Steam, the game “Bionic Commando: Rearmed” doesn’t work on your operating system and that’s the reason why you can’t add it to Steam.
Bionic Commando: Rearmed only supports Windows XP Service Pack 2 and Windows Vista. And obviously, you are not using Microsoft Windows Vista. Before you install any games from Steam on your computer, you need to check the system requirements first to know if it supports your operating system or not and so you can add it to Steam.
Try other games on Steam that supports Windows 7 so adding it to Steam won’t be difficult.
