BIOS reset application and tutorial
Hello, experts! I am in a big trouble. I want to reset my BIOS so that I can fix up hassle. Actually, I am looking for BIOS reset application and it's comprehensive tutorial. Please help me!
You can reset you BIOS using the following steps-
1) Open up your CPU and look for a pill type battery (lithium battery or CMOS battery).
2) Remove the battery, wait for a few seconds and put it back. Now your BIOS should be reset. If not, you will find 3 pins called CMOS jumper with 2 pins always coupled. If pins 1 and 2 are coupled then remove the cap and place it on 2 and 3, wait for 15 seconds and place the cap back to 1 and 2 pins. NOTE CMOS battery should not be removed while your are doing this.
Battery and the CMOS jumper is shown below-
