Is it possible to get the Bios Scan tool free of cost. I need a tool that will get information on the type of BIOS that the computer runs along with chipset type. It should also get information on CPU, RAM and ROM. Please do the needful for suggesting the best Bios Scan tool.
If you just want to see the system information about your bios just see the POST message when you start your PC, or if you want you can try using “BIOS agent plus” it is a software that can see the version of you BIOS, version of your computer and other related system information just follow this link to download https://www.filecluster.com/BIOS-Agent-Plus.html Hope this helps.
