BIOS Setting on old System
Please give me some tips on how and where I can download the BIOS setting of my old system to the Macintosh SE Atari Jaguar, Apple 1 & Intel Vision Sega Mark III.
Many thanks.
Many thanks.
Hello Victoris Rodgers,
I think the best place to get the BIOS setting for your old Mac system and download them is from the apple website. I will direct you to the site where you can download the BIOS settings, but then you will have to download another program called iboot for you to be able to install with the BIOS settings.
Once you have downloaded iboot, you will the burn its image to a CD and then insert the CD into a DVD drive on your computer. You will then restart the computer and then you will be prompted to remove the iboot after the BIOS settings have installed.
Regards
Mahesh Babu
