On my PC I can safely start and browse any web page. But as soon as I start using Bitcomet than I have to face an error message which says,
Problem loading page.
Keeping the download limit even to 25kbp/s didn’t work. My download speed is 112kbps. Restarting PC also didn’t make any sense. Any idea?
Your effective suggestion will be highly appreciated.
Bitcomet – Problem loading page.
Hi Judith,
The network bandwidth available to you is sufficient for Bitcomet and normal web browsing. But you do need to limit the bandwidth taken by Bitcomet like you have done. The other thing that you should do is limit the number of connections made by Bitcomet, if it makes a large number of connections it could affect your web browsing capabilities. Go to the options menu in Bitcomet and set a limit to the maximum number of connections that can be made.
