How come Bitdefender IS 2011 firewall would block me whenever I start my Windows update?
Is there any way to stop this error message from appearing. It has pissed me off for 24 hrs already.
Will it be okay if I add Windows firewall update sites to my FW settings manually?
I have tried disabling Bitdefender FW and let Windows update, but when I enable the update process again, the update does not connect.
Windows Update
windows could not search or new updates
An error occurred while checking for new updates for your computer.
Error(s) found:
Code 80040154 Windows Update encountered an unknown error.
Get help with this error
Most recent check for updates 4/17/2010 at 1:43 PM
Updates were installed 4/17/2010 at 2:17 PM
View update history
You received update For Windows and other products from Microsoft Update
Find out more about from Microsoft Update. Click here for details.
Do I have to reinstall or maybe repair everything?
Do I still have another option?
Please help me solve this issue.
Thank you.
Bitdefender IS 2011 firewall blocks Windows update
Hello Donald Hammond, I have read your query.
Problem seems to be with Windows Updates, not your Bit Defender Firewall Module. You will have to reset your Windows Update Components to resolve this issue. You can diagnose and fix this problem automatically by using an automated troubleshooter “Fix it” from Microsoft.
Microsoft Fix it can be downloaded from this link.
After download, run this tool and follow onscreen instructions. Chances are you get your issue fixed by this tool.
You can alternatively reset the Windows Update Components by yourself. This is a tricky process and involves changing registry entries. One small mistake and you may encounter a serious problem. So I’ll suggest you to avoid this if you can, otherwise contact some expert from Microsoft.
You can also try adding exceptions to Bit Defender Firewall for these links http://*.update.microsoft.com, https://*.update.microsoft.com and http://download.windowsupdate.com
On the other hand, if nothing works, you can try removing Bit Defender from your PC with the help of Bit Defender Uninstall Toll. You can download this tool from here
Hope it helped.
