Hi there,
Every time I want to log in into Management Server I have this invalid password. The problem is that I have this password from the beginning and I never change it and also I was not hacked. Any solution for this error ? Why my password is invalid now ?
OK
BitDefender Management Console – Connecting to server
Invalid password !
OK
BitDefender Management Console says invalid password
The error appears because of the invalid password when connecting to console therefore you should try again to connect with the default password 'admin'. For more information about the passwords, visit http://www.bitdefender.com/support/Bitdefender-Management-Server-Passwords-816.html
I will strongly recommend you to make sure the logon settings and the username will always be administrator. I hope this will help you to resolve the issue.
