After I finish to scan my PC I saw that some object were not found. I don’t know what it means or if harms my PC so can anyone tell me more about this ? Are these errors ? How can I repair them ?
Thank you !
Bitdefender Total Security
Object Path:
File: C:System Volume Information{08d4c852-8205-11e3-a40d-9cb70d0125… (object not found)
File: C:System Volume Information{e3abb5f7-9232-11e3-8c72-9cb70d0125… (object not found)
File: C:System Volume Information{3808876b-c176-4e48-b7ae-04046e6cc752)…(object not found)
File: C:System Volume Information{810c6fc9-9269-11e3-9485-9cb70d012528…(object not found)
Bitdefender Total Security error occurred
Those objects displayed in the log of your antivirus that were not found are actually harmless. Since these objects were found in the System Volume Information folder of the system drive, maybe the applications linked to them were already removed or uninstalled. Entries or objects in the System Volume Information folder of the drive are created during system check which is done automatically by the operating system or during software installation.
The main purpose of these objects in the System Volume Information directory is to restore the state of the computer to a specific date. In your case, you can totally ignore them because they cannot harm your system in any way. As time passes by, old objects in the System Volume Information folder are removed if the size of the folder will exceed the set limit.
Those objects that were not found will soon be removed from the folder when time comes.
