Hello.
I want to use the Bitdefender security but I would like to know if which OS works best on this software?
What are the problems encountered for each OS upon installation and which do you favor most?
Again, Bitdefender windows 8 work on windows 7 but which is better?
Bitdefender Windows 8 work on Windows 7 but which is better?
Hello Mark,
As you mentioned Bitdefender is supported in both WIN 8 and 7 but my personal opinion is Bitdefender is best in WIN 7, because Bitdefender is there to support as an antivirus, now Windows 8 not so much come forward as there are so many software which are not supported in Windows 8, where windows 7 is best stable OS right now, so my opinion is to go with
Windows 7 to have a flawless experience.
Thank You.
