Bitmap file compatible with paint editor.
Icon to Bitmap is a utility allows one to open an icon file or icon library and view each icon stored in the file individually.
One can then extract the Bitmap data and save it as a Windows Bitmap file compatible with paint/other editor.
How can I combination the formats?
Answered By 270 points N/A #154805
Hello there,
I have read that you are having problems with a specific software that can edit an .ico and .bmp format. Well, there's nothing more to worry because most of the newly released image editor can handle both, like adobe Photoshop and Corel draw.
Though this two platform can eat too much of your system, you can try having pixel former instead. Just download and install it to your computer and your problem is solved.
Waall Mike
