Bitmap file read error occurred
They have communicated with Corel, but they have still to receive an answer. I hope that they should have on Monday. The bitmap in these files CKYK is all the photos that have been edited using Corel Photo – Print. I have used the same method for a pair of years with x 3 and I never had this problem.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: CProgram Files (x…
This application has requested the Runtime to terminate it in an
unusual way.
Please contact the application’s support team for more
information.
Experts; kindly invited me to all, please join soon to resolve this error message.
Best Answer by Luke N Marks
Answered By 10 points N/A #197952
Hello Ruthprobertson
Hope you are fine.This is a trouble of that there is not available write permission on some of your directories.In case of windows xp, try aspnet account folder to activate write permission.If you are using windows server-2003/2008 or vista or black horn that this function will be available at Network Service account.Hope this will help you.
With thanks
Greaney Mary
Answered By 85 points N/A #139289
Hello
If you are having trouble with your Coreldraw.
Save and close all your artworks and close Coreldraw.
Hold the F8 key in on your keyboard
Start up Coreldraw.
A popup box will come up asking you if you want to reset your settings to default
Click yes.
This will reset Coreldraw back to the way it was when you first installed it. It will NOT delete any of your artworks.
