If you are still using operating system below iOS 8 follow the below given steps:-
Select General or App icons and then go to images then launch Images–> launch Images for asset catalog –> add desired resolution of the image for retina4 in the selection option.
So I guess the LaunchScreen.xib is useless if you target iOS < 8, unless you want to update both that and the asset catalog when the image changes.
