mart cullen 10 points N/APosted on - 05/24/2012
Hi! I always get the message, Error 523 everytime I use my BlackBerry phone. I had rebooted the phone but still the same error appears. Have no idea where to go from here and what seems to be the problem. Can anyone help please?
This problem happens on BlackBerry Smartphones with BlackBerry 7.1 and earlier operating system. The phone stops responding and then displays one of the following errors:
Error 523
App Error 523
JVM 523
The problem here is related to the JVM application or the Java Virtual Machine application which is used by the Application Manager of the BlackBerry Smartphone. The Java Virtual Machine encountered an error and is unable to continue running. To fix the problem, make sure the phone is running on the latest BlackBerry firmware. Visit How to update a BlackBerry Device to help you check for updates.
If you encounter this error and your BlackBerry is running on the latest BlackBerry firmware, try doing a hard reset. Turn off your phone then remove the battery. After a few seconds, reinstall the battery and turn it back on. See if this works. If the problem continues, visit How to force the detection of BlackBerry Smartphone to learn how to reload the BlackBerry firmware.
1....
