I am not so highly developed with IT and its sector. Anyway, I’m just searching for a few simple help or ideas. I got a 6-months old HP Bell laptop; it was running very well and reboots just fine. But now, I find the following error with a black screen and white font when I try to use it.
“PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Broadcom PXE ROM
No bootable device – insert boot disk and press any key.”
I need your help to solve this. Thanks a lot.
Black Screen and White Font with PXE Errors
Hi Kaycee Corpuz,
Kindly Check the back of your laptop for any kind of damage or check the back of its LCD if found any problem or damage Just bring to a repair shop or just to your provider. And if you haven’t found any damage on it just make a normal reboot and it will be back to normal. But if the reboot didn’t work follow the following steps that I will provide.
1.Another reason for you to get that error is because you have a problem on your hardware its either your Motherboard or a port inside is damage. Just do the first thing I said and it will be fix. (Go to your laptop provider or a professional Computer tech).
2.Another problem that might cause that is a problem with your bios. You haven’t updated it or it had a problem during your use. Just download it to their support site and it will be fix.
Friendly reminder: Always make a backup of everything important in your laptop just in case you will have another problem.
Contact me for any question that you might have.
