Black Series graphic card from Elitegroup
Elitegroup has launched its new Black series graphic cards for laptops and PC's.
I wanted to know about how it is different from Nvidia GeForce and AMD Graphic cards?
Hi there!
I’ll just give you the specs for the 3 graphics card so you can see the difference.
The Elitegroup GTX680 Black Series can run on a 2GB, 6008Mhz GDDR5 RAM. It has a 256 bit memory bus. Core clock can run at 1040 MHz. It also has a PCI-e 3.0 interface
The GeForce 605 can run on a 1GB, 898MHz DDR3 RAM. Processor clock is 1046 MHz. It has a 64 bit memory bus. It has a PCI-e 2.0 interface.
The AMD Radeon Graphics card runs on a 1GB, DDR5 RAM, 625-750 MHz engine clock. It has a 16 bit memory bus.
It has a It has a PCI-e 2.1 interface.
