Ragnyl
Posted on - 10/25/2011
When I first try the black berry, I am surprised that it can do some barcode scanning.
There are some available blue tooth barcode scanners that a blackberry can use.
Does this features of blackberry is the same as the barcode scanners that is used in the supermarket?Â
BlackBerry blue tooth barcode scanners ?
Hi Ragnyl,
Barcode is acategory  of parallel bars which identify the product or the objects.
In general perspective barcode in the supermarket is called UPC.Â
Many 2 dimensional or 2D are also utilized all over the world.
In which it is very different from the barcode UPC. Because 2D codes are vertically horizontally scanned which holds more data.
ID BARCODE
2DQR code facilitates marking of products and also the looks of the establishments. Â
This barcode is an example of blackberry scanner.
Hope this might help you.
Thanks,
Michael21
