BlackBerry Curve Insight Install Error
Dear techyV,
I have a new BlackBerry Curve and want to install a third party application. I was told that I can download the software over the air (OTA) but I don’t want OTA as I got the BlackBerry Desktop Software when buying.
No additional applications designed for your device were found
Error
No additional applications designed for your device were found.
                                 OK
How do I solve this problem?
Very grateful for the help
E
Answered By 20 points N/A #113722
Hi friend,
Installing a third party application for blackberry sometimes does not work out properly. So you need to be very careful about that third party application for blackberry and its versions. First detect version of software that you are installing. You can detect it by going its desktop manager properties.
find version information under blackberry desktop manager
In here go general tab and find version information under blackberry desktop manager. May be your version is 4.2. Now find update of that software. The latest version of that software is 4.3 which is available for now. Install this version. It works better than previous one.
You can also use other third party software for ultimate. Visit this link to find other supported software for blackberry provider. http://www.blackberryinsight.com/2007/05/12/howto-upgrade-your-blackberry-os/
