ronald luna
20 points
Posted on - 03/21/2012
Hello
If I tried to select any option, I got this 0x80040fb3 error message:
Intellisync Error encountered. Error code -0x80040fb3. Check documentation.
Please help me. I need your help.
Thanks a lot.
BlackBerry data synchronization problem occurred
I think the application is already processing something when the error pops up. Try again. It is possible that it is only a minor glitch on the system. Click OK then start again the operation.
If you still get the same error on the next attempt, if you are using a USB cable to synchronize your phone try transferring to another port in your computer and then try the procedure again. If it fails again, try uninstalling the phone’s application from your computer and then install it back.
This will fix any corrupted files in the installation and will also restore its settings back to default including some that you might have customized. After reinstalling the application, try again.
