My blackberry 8520 cannot open Skype on it, when i try to open the Skype it gives me error message. Tell me please, how can I fix this?
Error starting Skype_Lite:
Class
'net.rim.device.api.ui.Scroll
view' not found.
Blackberry does not open Skype
Hi Saraah, I have read your query on the error you encounter everytime you open Skype on your Blackberry 8520. I have done some research about it and found out that Blackberry 8520 model is not supported by Skype. If you want to see the list of Blackberry Smartphones that are supported by Skype, you can found it on this link,
https://www.skype.com/en/get-skype/
This problem often occurs due to the compatibility issues or it does not install properly due to the some reasons. You should perform some steps to solve this problem immediately.
You can solve this problem if you download Skype from the official website.
Search the app with your model number then you will find the right app for your mobile.
Download this application from the trusted website.
If you follow these steps then you will resolve this problem hopefully.Â
