Blackberry phone’s app for businessmen
i heard that bb just released the financial app and it will be a great help to all of the business, but what if someone steal the phone is there a protection for the financial info
Dear Judith Lauren Black Berry has a lot of financial application at their portal.
The main reason for the popularity of black berry is the financial applications of it and highly encryption services for the safety of data.
Black Berry comes with a Tracker that is web based GPS client. The better part is that it is free. It can not only locate your position but can also help as a anti theft tool.
This core feature is live and sends GPS coordinates are sent to the server by user specified interval.
Thus the coordinates data is in real time.
Hi Judith,
Thanks for posting your question here. you are asking about the protection of your financial files if someone will steal your phone. It has still protection if you encrypt all your financial files you saved on your financial applications you did but if you have not encrypt it is possible that they can view your financial data and this may cause that the privacy of your business will be ruined and your competitors of your business will know your weaknesses.
The following are some of the financial applications that you can download:
1. Shop Magic
2. trackIT:expense Edition
3. SplashMoney
4. powerOne
5. SplashID
Try using one of those application and learn to explore on how to use them. I hope this will help you.
