I have downloaded ebooks for my blackberry curve 9300 in epub format. It is already in my file list, but when I try to open it , it says "unsupported format". What are ebook format compatible with my blackberry model? Do I need to install an ebook reader for my handset?
Blackberry vs epub format compatibility
Hello Santos,
Epub has support for all notable devices except amazon kindle. If the case is different with you then you have to get a software to enable you read it. There are quite a number of them to help you read and even convert them. Calibre is a good software that performs a number of functions. It converts formats like chm, epub, fb2, html, mobi, lit, pdf and many more to epub, mobi, txt, pdf, pdb and many more. It’s good. You can also get Haihaisoft Epub reader, which is a free and fine app. Hope this helps you.
You could try doing this.
Double click the eBook you downloaded and let your pc decide which default application should open the file.
Or you can downloaded these free applications EPUB files namely: Calibre, Adobe Digital Editions, Stanza Desktop,
Mobipocket Reader Desktop and Ocular.
You could also downloaded Firefox Add-Ons like EPUBReader, it allows to read EPUB files in the browser just like any documents.
