Block Ip Address Using Toolator
I've been searching for tools that can help me block a certain IP from viewing my bloggersite. Luckily, I discovered Toolator because a friend told me about it. I just wanted to know the steps on how to block a IP addresses using this application. Can someone show the steps here?
Answered By 0 points N/A #80364
Toolator allows you to block 3 IP addresses so the first thing you need to do is to identify the IP addresses that you want to block. If you are using Blogger.com, you can use a site counter in order to track the IP address and time of visit to your site. When you have gathered the IP addresses you have to sign up to toolator. Follow the step-by-step procedure and provide them the IP addresses that you have.
After that, Toolator will generate a code that you need to paste on the footer of your blog website. What happens after that is the owner of the IP address that you blocked will be redirected to Toolator and will have no access to your site.
