Blocking Unknown numbers on IPhone 5
Hello Everyone! I am an IPhone user and there is this unknown number which calls me many times in a day just to harrass me. Obviously I don't like this happening everyday. I need to know how to block unknown numbers. I mean obviously I cannot go to settings and add a new block for an unknown number. What is the solution? Thanks!
Answered By 0 points N/A #182399
You can block the unknown number in your “iphone” mobile by following these few steps:
· Firstly, tap on the “Phone Icon” on your “iphone” with your finger.
· Then, tap the “Recents” button option in your “iphone” with your finger.
· After that, tap on the “i” circle which can be found next to the unknown caller, which you want to block.
· Then, scroll it with your fingers to the bottom of the screen.
· After that, tap “Block this Caller” option on your “iphone” with your finger.
· And then, tap “Block Contact” option on your “iphone” with your finger to block that unknown person.
Hope this answer will help you a lot.
