BLOGGER Recent Post script doesn’t show thumbnails
I have two BLOGGER sites where on the right side bar; I pasted a script showing the recent post. On the main page, the recent posts shows a thumbnail images while on the other section of my site doesn’t shows the thumbnail.
Could you please help us why this happened or how to fix the problem?
Thanks in advance.
The BLOGGER site is http://honeybytes.blogspot.com/;
Please check the music section to see the problem I am talking about.
Answered By 0 points N/A #102417
Hello Eloise
Blogger.com is very easy but still have some restricted format. The recent post on your blog either HTML code or direct submit i am not sure. If it is from HTML or Java then try to keep right code in line. i think this happened for code break.
Direct writing posts will happen the image alignment, size can not support. as the blogger.com requires some option to posts new. Just keep existence file to post the file.
The posts style,color, and more settings you changes only the similar default setting might be supported. So have this edit and repost this. By HTML/CSS coding best and decorated post if possible.
re-stare your published post. see above terms
Thanks
