From Blogspot to WordPress Platform
I currently have a blog on blogspot.com and I wish to transfer to wordpress. Is there a way to transfer all the content of my existing blog to wordpress.
You can easily transfer all the content of your existing blog to wordpress. There is a free Blogger Importer plugin inside wordpress by which you can do this job. So, sign in to your wordpress account. Go to Manage. Then click import and at last select blogger. Then you will have to authorize your blogger account. Submit necessary information there and you are done. All your posts, comments and users of blogspot will be visible in WordPress after some times. Hope you found your answer.
Yes you can transfer your blogs in WordPress just check if there are some options in WordPress that you can transfer your blogs to WordPress and make sure that blogspot.com have the options also to transfer your blog to WordPress most important to avoid plagiarism this might get you in trouble in some blogging sites.
Notifications
