when I tried to install blu-ray disc suite on my system it gives me the following error and does not allow me to install the software can anyone tell me how to manage installing it? Any help?
InstallShield Wizard You have to log on as the local administrator to install Blu-ray Disc Suite properly. Installation will now abort.
Blu ray Disc Suite Error
Hello Mr. Killen,
For two reasons this problem may occur-
1. If you are not using the administration user account to log in.
2. The software you are using is not compatible with your operating system.
First you should check the user account you are using to log in, it should be an administrator user account. Then you have to install the software.
You can use Cyber Link blue-ray disk suite software for the compatibility issue, because this software is compatible at windows XP as well as windows 7.
