Blue line on lg monitor
HI, I have a fletron w1742s monitor , from few days on my LCD screen appearing a thin blue line in left side,if have any solution please advice.
Hello, You told that you have a LG fletron w1742s monitor which is appearing a thin blue line in left side. Actually its a display problem of your LCD monitor. Normally this problem cannot be solve. If you have warranty of this product you can give it to the shop from where you purchase it. Another solution is that you have change the LCD panel of your monitor.
Thanks
Eaana Albert
Hi
When an LCD monitor starts to display this type of error, it is a sign of faulty LCD monitor panel. I suggest you take it to a specialized service center for this type of brand. Bear in mind that the cost of repairing will be much for this type of fault. You may consider getting another one.
